Mach Discussion => General Mach Discussion => Topic started by: compunerdy on April 02, 2006, 05:27:34 PM
Title: Need help configuring axis please
Post by: compunerdy on April 02, 2006, 05:27:34 PM
On my lathe I am reusing the stock cross slide screw and I am not positive how to set it up.
I have learned that the cross slide moves .0394 per revolution.
The motor is direct coupled to the screw.
My stepper driver uses 8 micro steps
Do I need more info than this?
I came up with 40,608 Mach 3 steps per unit.
Thanks, Tim
Title: Re: Need help configuring axis please
Post by: Brian Barker on April 02, 2006, 05:54:50 PM
I get 40598.9 steps per unit...
Post by: compunerdy on April 02, 2006, 05:59:38 PM
I must have rounded ???
Ok..just wanted to make sure that sounded correct. Thanks again
Post by: Hood on April 02, 2006, 06:00:08 PM
Not used to inches but 0.0394 per rev seems quite small, is that correct?
Post by: compunerdy on April 02, 2006, 06:09:35 PM
This is what I used to base that number on.
http://www.littlemachineshop.com/products/product_view.php?ProductID=1387
Tim
Post by: Hood on April 02, 2006, 06:11:37 PM
Yes I worked it out as 1mm, just seemed a bit fine but it is correct.
Post by: Hood on April 02, 2006, 06:14:43 PM
actually for your calcs you would be best keeping all the figures on your calculator so divide 1 by 25.4 and your conversion will work out more accurate and may even end up with a better figure to enter into Mach ;)
