Mach Discussion => Mach4 General Discussion => Topic started by: Mauri on July 19, 2019, 06:56:24 PM
Brian and others at Mach4.
This has been a long saga, and when programmers are programming they do not always take into consideration the real world.
Please review the attached PDF and see if in someway you can fix the Mach4 Toolpath so it actually can be used in the real world of machining for any user performing 4/5 Axis processing on a Mill or Router Table.
Having a program that displays correctly in Simulation Only is not what users I am sure want.
Mauri.
