Mach Discussion => General Mach Discussion => Topic started by: paul40 on May 28, 2019, 02:40:02 PM
Ok here we go.
I am trying to setup my 4th axis in mach3. This is what I have done so far with no luck.
I have got Mach loaded on my laptop, windows 10. I have 4 NEMA 34 steppers and drivers and 1 NEMA 23 on the 4th rotary axis plus driver.
Then I have a novusun 6 axis controller USB. I have setup X,Y plus slave as A axis and Z axis in ports and pins and motor tunning. I then setup my 4th axis as the B axis. The problem I have is that the 4th axis is not turning and the DRO is not moving when I am using the MPG in mach3. When I deactivate the slave A on the Y axis then the DRO on the 4th axis starts running but the motor still don't run.
I just don't know what ells to try, please I will appreciate any help you guys and girls can give me.
Regards.
Paul.
Hi paul40,
Unfortunately Novusun is one of the businesses listed in our Hall of Shame for Mach3 Licence violation. As a result this forum does not support assistance with any of it's products unless you are a genuine Mach3 or Mach4 license holder.
This thread referrers; https://www.machsupport.com/forum/index.php?topic=24331.msg238650#msg238650
