Mach Discussion => Mach Screens => Topic started by: RMT on August 30, 2007, 04:38:17 PM
Is it possible to apply the feedrate override to the jog rate, so that there would be a button that applies the lowered feedrate also to the jograte and an led that inticates that you are jogging at the lower rate set int the feed rate override?
I'm working with the simple 3 axis screen and the only way to jog in continious mode is full bore.
I created a button and tried oem code 287 rapid override but it doedn't affect the jog rate neither does oem 202 feed override jog whatever that means.
Thanks for any help
Frank
