Third party software and hardware support forums. => HiCON Motion Controller => Topic started by: marc1b on April 22, 2019, 10:58:35 AM
In the process of chasing down a problem with interpolating a circle I updated the firmware to 3.26b and .xsvf to IntegraFPGA_7E7B
Integra 7766 & 7737 , Maxsine drives & motors
Aside from the circle error everything was fine before the updates. I am embarrassed to say that I didn't make a record of the motor settings in the Hicon plug in and I am pretty sure that is where my problem is. What should the index & output be for 3 axis?
I have found a few differences in the pin mapping between the older version of the 7737 manual and the newer. Is there something I should be changing here?
I decided better to move forward than backwards, I am upgrading to Mach4
