Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: vmax549 on August 20, 2007, 07:59:39 PM
Title: NFW request
Post by: vmax549 on August 20, 2007, 07:59:39 PM
Ron while using the NFW suites it seems that the wizards  assume that the "top of work" Z value is always Zero. This makes it hard to integrate the wizard code into other Gcode programs. Could you change that to have an input for the top of work Zvalue?
Thansk (;-) TP
Title: Re: NFW request
Post by: Ron Ginger on August 21, 2007, 02:57:01 PM
If you mean for every wizard in the set, I think I'm to old to start a project like that. :-)
I did look at adding a Ztop to the surfacing wizard, I may be able to add that when I finish the step over problem.
Post by: vmax549 on August 21, 2007, 03:56:48 PM
Hi Ron , I am not a wizard at programing BUT it seems that it should only be a few lines of code and a entry dro. You are only substituting a variable for a set value. Pretty please ???
You can't be that old(;-)  I am as old as dirt and I did not see you splashing around in the water when I poped up.
