G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: docltf on August 18, 2007, 05:00:05 PM
Title: move to new layer
Post by: docltf on August 18, 2007, 05:00:05 PM
BRIAN
       is it possible to fix lcam pro so that when you use sel in box, that after you select your chains you can right click the mouse
       and select move to new layer.and also be able to do the same thing when using single/multiple setting.
thanks bill
Title: Re: move to new layer
Post by: Brian Barker on August 18, 2007, 08:25:29 PM
We can look into that ... I can see where that could be a big help.
Brian
Post by: docltf on August 19, 2007, 12:36:54 PM
BRIAN
        can you also do a right click zoom in the project window, so that when you zoom a layer or a chain the selection
       will be as large as it can get in the display window and hide the rest of the drawing.this will help when trying to
       clean up a dxf from a scanned image.
bill
Post by: Brian Barker on August 20, 2007, 08:58:27 PM
I don't think I understand what you are looking for :(
Sorry
Brian
Post by: docltf on August 20, 2007, 11:37:52 PM
the left window where the chains and layers are.when you left mouse click a chain it highlights the chain in the display window.can you
put a right click that will  full zoom. and when you pick a chain you can zoom the chain only.and if you pick a layer it will only zoom
that layer.
thanks bill
