G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Edward on April 05, 2019, 05:58:21 AM
Hello
I have a feed rate issue from running a Multicam Post Processed file on Mach3 for CNCRP.
I think I have fixed most of the other problems but cannot find a way of changing the feed rate units from mm/sec to mm/min without manually changing the g-code itself.
Is there a setting in Mach3 I can change for this?
Many thanks
Edward
https://forums.autodesk.com/t5/hsm-post-processor-forum/feedrate-units-adjustment/td-p/8514266
What CAM software are you using?
UPDATE
I think I was not completely clear earlier. We have a large library of g-code files (around 300) and want to run these directly on our new machine Mach3 CNCRP Pro. The code seems to work fine (with a few settings changed) except for the feed rate which is at mm/sec in the file and mm/min in Mach3.
Making changes to the post processor or g-code is not really an option as it will mean having to manually alter over 300 files - it may come to this but I would like to avoid it.
So my question is can I change the feed rate units at the Mach3 end of things? - not the post processor or gcode end.
Many thanks
E
Not that I'm aware of.
How about if you could modify the FRO to go to 600% ?
Would that not feed 10 mm/sec in the code, 10 mm/min on the machine ?
Russ
I think you'd need 6000%.
Then there's that Mach3 bug that can cause issues when running over 200%....
Hmmm ... wasn't aware of the bug.
But, wouldn't you just multiply by 60 (600%) ? seconds to minutes ? not mm to meters ?
100% is normal speed.
100x60 = 6000
::) dohhhhh ;D, Sure you're right.
Just wondering if Mach4 could effectively multiply the feedrate by 60.
If so, maybe Mach 4 would be an option to consider ?
Sounds like you need someone to write you a simple utility to scan teh Gcode and Convert all the "Fnnn" strings to ( Fnnn X 60).
Just a thought , (;-) TP
Hello
Many thanks
Edward
I think it could be done using a MACH3 BRAIN.
I will try to create one BRAIN ASAP. Just trying to make certain which DRO label means what.
Hello
Many thanks
Edward
Sorry, i tried but it cannot be done.
