Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: Chaoticone on August 16, 2007, 07:34:22 AM
I welcome input from other members.
You can download the latest copy here. I welcome input from other members. I won't be posting the actual file any more, only a link. This is the best way I know to insure that you will be getting the latest copy.
http://www.machsupport.com/Downloads/machdownloads/G100_Set_Up_Guide_Rev.1_9-19-07.pdf
Please check the link. It ain't right.
NewB
You are right, I fixed it. :) It must have gotten changed in the server swap.
Thanks for the guide. It REALLY helped!
A major omission though. With windowsXp you must either turn off the firewall for your local net or better yet add mach3 and gRexloader to the exempted applications.
I just had fun trying to figure out why on two nearly identical computers, one worked completely and the other couldn't run gRexloader or Mach3 but could be pinged, and amazingly successfully loaded with firmware and fpga code from IE using the IP address. The G100 was setup about 9 months ago on the first computer and still worked.
I had seen a post about the firewall but the firest machine worked fine with it enabled. Both computers had the firewall enabled with the same port and application exceptions on both so I didn't think the firewall was the problem. gRexloader and Mach3 could never connect to the g100. As soon as I disabled the firewall it worked. Adding gRexLoader and Mach3 to the exceptions and enabling the firewall also worked.
I can only figure that some of the windoz updates that have been installed in the last 9 months somehow allowed the existing setup to work but when I built the new system the firewall had to be configured more strictly. Hope this helps someone.
Thanks for the info.
Sorry but I can't get the link working , can you please re-post?
thanks
mariano
http://www.machsupport.com/docs/G100_Set_Up_Guide_Rev.1_9-19-07.pdf
With the passage of time the location of links inevitably change. This should be a current location;
ftp://anonymous:guest@ftp.machsupport.com/Docs/G100_Set_Up_Guide_Rev.1_9-19-07.pdf (ftp://anonymous:guest@ftp.machsupport.com/Docs/G100_Set_Up_Guide_Rev.1_9-19-07.pdf)
