Mach Discussion => General Mach Discussion => Topic started by: Stvktchn on March 29, 2019, 06:51:52 PM
Title: Z axis when I start Gcode just plunges into work
Post by: Stvktchn on March 29, 2019, 06:51:52 PM
Hello so I have not really had much luck getting my machine set up properly. I try running the skull and crossbones it runs through the code but it never touches the work piece. So I try some Gcode that I created which is just a circle .25 deep and it just plunges into work piece and bottoms out.  Any help would be great
Title: Re: Z axis when I start Gcode just plunges into work
Post by: reuelt on March 29, 2019, 07:34:22 PM
Are you using MACH3 or MACH4?
Normally, you need to jog (TAB key will give you Jog screen + arrow keys to jog) to the zero point of your workpiece at set work coordinates to zero.
Z = 0 is when your bit just touch the surface of the workpiece.
regenerate tool path
Then Cycle Start
Post by: Stvktchn on March 29, 2019, 08:02:50 PM
Mach 3.   Ok I will try that thank you
