Mach Discussion => Mach4 General Discussion => Topic started by: TTalma on March 21, 2019, 05:36:24 PM
Title: Is there a Gcode command to reference all axis home?
Post by: TTalma on March 21, 2019, 05:36:24 PM
When I am hogging material off for a rough clean up some times I lose a couple of steps. For the roughing it doesn't really matter, but it does on the following steps.
Is there a Gcode command that will reference all axis home?
I know about the G28 command but this only returns the axis to the home position, it doesn't appear to reference it from the switch if it's off a few steps.
Title: Re: Is there a Gcode command to reference all axis home?
Post by: joeaverage on March 21, 2019, 09:29:48 PM
no, there is no Gcode that does that.
There is however a Mach function that does it:
LUA Syntax:
rc = mc.mcAxisHomeAll(
   number mInst)
Description:
Used to start an axis homing.
Parameters: Parameter Description
mInst The controller instance.
Returns: Return Code Description
MERROR_NOERROR No Error.
MERROR_INVALID_INSTANCE The mInst parameter was out of range.
MERROR_NOT_NOW The operation could not be completed at this time.
Thus you could use the API in a macro.
Or you could call the RefAllHome() function (in the screen load script)
Code: [Select]
-- Ref All Home() function.
function RefAllHome()
    mc.mcAxisDerefAll(inst)  --Just to turn off all ref leds
    mc.mcAxisHomeAll(inst)
    coroutine.yield() --yield coroutine so we can do the following after motion stops
    ----See ref all home button and plc script for coroutine.create and coroutine.resume
    wx.wxMessageBox('Referencing is complete')
end
Post by: Cbyrdtopper on March 22, 2019, 07:47:45 AM
There is a G Command that will home an axis.
G28.1   It is on page 37 of the mill programming manual.
I just tested it here at work on a mill with the ESS and it works.
I found that it needs to be programmed like G28, with a G91
So, do the following.
G91 G28.1 Z 0.00
G91 G28.1 X 0.00 Y 0.00
G90
Be sure to set your machine back in absolute mode with the G90.
Post by: Overloaded on March 22, 2019, 08:23:52 AM
Hi Chad.
Are you referring to the doc in the M4 download ? Mine is different.
Or are you in M3 ?
Russ
Post by: Bill_O on March 22, 2019, 08:33:17 AM
I am using the
G90
in M4 and it works great.
Bill
Post by: Overloaded on March 22, 2019, 08:53:26 AM
Hi Bill.
I don't doubt that it works in M4, as it worked well in M3 but I don't see it in the M4 manual. Mine goes from 28 to 30.  Do you have it in a M4 manual ?
Post by: Cbyrdtopper on March 22, 2019, 09:06:01 AM
It's in the Mach4 manual.  Page 37.
Post by: bryannab on March 22, 2019, 09:07:12 AM
Hello,
G28.1 is included in the Mill G Code Programming document in the Mach4 Docs folder. The one I'm looking at is version 1.1, build 3775 and is included in 4.2.3804 and onwards.
-Bryanna
Post by: Overloaded on March 22, 2019, 09:19:53 AM
Thanks bryannab,
I have 1.0 .
A day late and a dollar short again.
Cheers,
Russ
Oh, I got it here
https://www.machsupport.com/help-learning/product-manuals/
You might want to update that.
Post by: Overloaded on March 22, 2019, 09:27:34 AM
Thanks Chad.
The current manual has not replaced the old one yet on the website under Mach4 Manuals.
Russ
Post by: Cbyrdtopper on March 22, 2019, 09:38:23 AM
Russ,
Yeah, I have the newest profile from the FTP site on my computer at work, so my manual is updated, didn't even think about it not being in the older manuals.
Post by: Bill_O on March 22, 2019, 02:30:45 PM
My only problem with the G28.1 is the speed is very slow.
I can not find how to change the speed.
Post by: MN300 on March 22, 2019, 02:44:02 PM
You have said the error is small. You could do a high speed move to a location near home before the G28.1 command to speed things up.
Post by: Cbyrdtopper on March 22, 2019, 02:45:50 PM
That'w what I was going to suggest.
It homes as if you clicked the Reference button; command a G53 move close to Axis Zero.
Post by: smurph on March 24, 2019, 12:54:53 PM
The home speed is configured in Homing/Softlimits tab as a percentage of the axis' maximum velocity.  The axis maximum velocity is derived from the slowest of the motors that run the axis (Motors tab).
Steve
