Mach Discussion => Mach4 General Discussion => Topic started by: jeff1973 on February 16, 2019, 04:58:33 AM
Hi All,
I Need an M function to disable the SRO especially when taping ,Is this possible with mach4
yes it is possible.
Look in the 'Spindle' category of the Mach AI.chm:
LUA Syntax:
rc = mc.mcSpindleSetOverride(
number mInst,
number percent)
Description:
Set the spindle override percentage.
You could use this or you might experiment with another from the same category:
LUA Syntax:
rc = mc.mcSpindleSetOverrideEnable(
number mInst,
number enable)
This API determines whether a SRO is applied at all.
