Mach Discussion => Mach Screens => Topic started by: Kenneth on February 04, 2019, 11:45:01 AM
Below is a script i made with machscreen v1.7. but it tells me the the command is too long and points to the block(first line).
hope someone can help me. Thanks
'probe on Z axis
Probe = 1.89 'probe height
Depth = -1.5 'z negative travel
Feed = 4
Code "G20 G31 Z" & Depth & " F" & Feed
While IsMoving()
Wend
SetOEMDRO(802,Probe)
While IsMoving()
Wend
Code "G91 G00 Z.2"
While IsMoving()
Wend
Code "G90"
End
64 bit
win 10 pro
24g ram
3.4g processor
sorry, using Mach 3
I don't know if it helps but the line;
Should read;
Call SetOEMDRO(802,Probe)
Thanks Tweakie.CNC, i tried that and same error. i think there may be something that
tells the code that there's an end of line.since the error includes the first two lines.
i also have a corner probe button without the "Call" inserted and works fine.
i'm at a lost but will keep looking. Thanks for your info !
try to copy the code from machsreen Editor to an other Editor like Notepad++, just to see that there is a correct CRLF at the
end of each line.
there are no CRLF at the end of any line. does have NUL at end of file.
THANKS TPS
Hi Kenneth
When do you get that error message? When entering use data and close, or when you close MachScreen?
Klaus
i get the error message when i use the button in mach3.
its in the error label. where the estop message is.
Thanks Klaus !
Hi Kenneth,
did you try to debug your script in Mach3 with the script debugger?
Select your page with the button
Menu Operator -> Edit button script
click the flashing button of interest
Klaus
i didn't think of that. let me try.
Thanks Klaus
it won't let me edit it in mach3. the other buttons i can edit.
Thanks Klaus
Hi Kenneth,
you could send me your screenset files including the script to have a look at it. My email klaus.dietz@kd-dietz.de
Klaus
on it's way.
Hi Kenneth,
I suppose the buton of interest is "Height Probe". Try to change the "Standard Code" to 34 (Std Execute Basic-Script)
Klaus
sorry, yes it's the "height probe" button. ok i'll try that.
THANKS.
i changed the oem and it works but i close mach3 and opened it again and now
ESTOP doesn't work. i had a script for it but i changed it to oem 1021. but still nothing.
THANKS Klaus for your attention and patience !
Hi Kenneth,
glad, I could help
Klaus
