Mach Discussion => General Mach Discussion => Topic started by: falcon120 on January 27, 2019, 03:56:51 AM
Someone knows this card
nvum v2 3 axis.
I can not make the thread because mach3 is waiting for the index pulse.
if I connect index to input as per manual, read the rpm correctly but without the index lamp lights up.
Instead if I connect index to another input(like proximity switch) , the index light turns on but does not read the rpm and if I try to do threading, mach3 remains waiting for the thread signal…..
I have sent you a PM.
