Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: greenene on January 11, 2019, 07:43:58 AM
Title: Z moves up when uc100 disconnects
Post by: greenene on January 11, 2019, 07:43:58 AM
I've had Uc100 for quite some time without any issues. Lately, I noticed that  the UC100 gives me a "disconnect" error with USB, which stops the job midway. If I disconnect the USB cable from the pc, the z axis starts moving up until I reconnect it again. Is there a way to prevent this in mach3 ? With the z axis moving up, I have no time to diagnose the problem, which forces me to turn off the entire system ans start all over again.
tony
Title: Re: Z moves up when uc100 disconnects
Post by: ger21 on January 11, 2019, 10:55:04 AM
Once the UC100 is disconnected, the axis shouldn't be moving at all. Sounds like a serious noise issue is both causing the disconnect, and causing the Z axis motion?
