Mach Discussion => FAQs => Topic started by: yiannis_nter on January 06, 2019, 02:55:15 PM
Hello,
I am new in mach3.
my pc crashes when I run Mach3. My OS is windows 10 32 bit. I have also run the special driver. Thank you in advance
The parallel port driver will not work in Windows 10. You either need to use a 32bit version of Windows 7, or buy an external controller like a UC100 or ESS.
Hello, I took a uC100, but my pc crashes when I start the software without connecting the controller
Make sure you are using the latest version of Mach3 from the website. It's the only version that will run in Windows 10.
take a look here:
https://www.machsupport.com/forum/index.php?topic=37291.0
Thanks for the interest
