Mach Discussion => VB and the development of wizards => Topic started by: birillo1959 on December 23, 2018, 06:18:56 AM
Good morning
I have the following script for "REFF ALL HOME" modified a window two buttons "NORMAL and FAST" (I had the TPS user had me) the normal part works fine.
what I would like to change is the fast part:
1) the "Z" rises to the origin
2) "X and Y" at the same time
I state that I have no skills with VB, I thank those who can help me
GOOD HOLIDAYS TO EVERYONE!
Sub Main
Begin Dialog SelectCentering 350,145,125,96,"REFF ALL HOME"
OKButton 20,68,40,14
CancelButton 70,68,40,14
GroupBox 30,5,72,52,"REFF ALL HOME",.GroupBox1
OptionGroup .OptionGroup1
OptionButton 46,24,54,8," NORMALE",.OptionButton1
OptionButton 46,40,54,8," VELOCE" ,.OptionButton2
End Dialog
Dim Dlg1 As SelectCentering
Button = Dialog (Dlg1)
If Button = 0 Then Exit Sub
Selected = Dlg1.OptionGroup1
'NORMALE is selected ********************************************************************
If Selected = 0 Then '*****************************************************************
Speak (" zero macchina") 'Avviso Vocale
Message "************ ZERO MACCHINA ************"
Sleep (1000) ' pausa di 1 secondi
DoButton(24)
RefCombination(3)
'DoButton(23)
'DoButton(22)
'DoButton(25)
While IsMoving()
Sleep(100)
Wend
SetParam("XRefPer", GetParam("XRefPer")/15)
SetParam("YRefPer", GetParam("YRefPer")/15)
SetParam("ZRefPer", GetParam("ZRefPer")/15)
'SetParam("ARefPer", GetParam("ARefPer")/15)
DoButton(24)
RefCombination(3)
'DoButton(23)
'DoButton(22)
'DoButton(25)
While IsMoving()
Sleep(100)
Wend
SetParam("XRefPer", GetParam("XRefPer")*15)
SetParam("YRefPer", GetParam("YRefPer")*15)
SetParam("ZRefPer", GetParam("ZRefPer")*15)
'SetParam("ARefPer", GetParam("ARefPer")*15)
Speak ("zero macchina completato") 'Avviso Vocale
End If '********************************************************************************
'VELOCE is selected ***********************************************************************
If Selected = 1 Then '******************************************************************
Speak (" zero macchina veloce") 'Avviso Vocale
Message "*** ZERO MACCHINA VELOCE ***"
RefCombination(7)
'RefCombination(15)
Sleep(300)
'While ((GetOemLed(807) = true) Or (GetOemLed(808) = true) Or (GetOemLed(809) = true) Or (GetOemLed(810) = true))
While ((GetOemLed(807) = true) Or (GetOemLed(808) = true) Or (GetOemLed(809) = true))
Sleep(50)
Wend
RefCombination(7)
'RefCombination(15)
Sleep(300)
'While ((GetOemLed(807) = true) Or (GetOemLed(808) = true) Or (GetOemLed(809) = true) Or (GetOemLed(809) = true))
Sleep(50)
Wend
Speak ("ZERO MACCHINA VELOCE COMPLETATO") 'Avviso Vocale
