Mach Discussion => Mach4 General Discussion => Topic started by: CNCharly on November 14, 2018, 03:39:35 AM
I configure it in the tools menu and press enter. If I recall the tools menu the configuration is set back to 'T on M6 line is next tool'. Also it works so.
My Logfile shows:
2018-11-14 10:16:09.029 - Logging Enabled.
2018-11-14 10:16:15.404 - API: mcCntlConfigStart(inst = 0) (Mach4GUI)
2018-11-14 10:16:15.404 - Attempt transition from "Idle" on event "Config" MachAPI.cpp:3622
2018-11-14 10:16:15.404 - S_IDLE_on_exit
2018-11-14 10:16:15.404 - ACTION_start_config
2018-11-14 10:16:15.404 - S_CONFIG_on_entry
2018-11-14 10:27:43.855 - API: mcCntlConfigStopEx(inst = 0, reload = 0) (Mach4GUI)
2018-11-14 10:27:43.855 - Attempt transition from "Config" on event "Stop Config" MachAPI.cpp:3652
2018-11-14 10:27:43.855 - S_CONFIG_on_exit
2018-11-14 10:27:43.887 - ACTION_stop_config
2018-11-14 10:27:43.887 - S_IDLE_on_entry
I am running version 3893. I run 3835 before with same problem and hopped, installing the latest version would solve my problem.
Is there any other setup which influences this config part? What cold be the reason for this misbehavior.
Karl
You do realise that the ones on the ftp site are beta not release ones
It clearly states the these are not fully tested
Try 4804
I know the risks, no problem.
I found out that the problem happened only in my standard profile, so I 'imported' it into the new installation also. I deleted this one and created it anew. > Problem solved.
Karl
Good that you know the risks involved
Also glad you have it sorted
There was one build a long time ago that nearly caused a cars for me , I have my mill in metric ,the problem was jog down incremental mode set to 1 ok first time then next it went down 25.4 mm
