Mach Discussion => Mach4 General Discussion => Topic started by: Raymondo on November 05, 2018, 06:00:05 PM
Hi
I had Mach4 running under XP pro SP3 I did a fresh install of XP on the same computer with XP pro SP3
I tried mach4 4.2 3233 and get error "could not initialize the core"
I tried Mach4 4.2 3804 and get error "could not initialize the core RC=-17"
I am at a loss to know what to try it had worked the new copy of XP seems to be running perfectly apart from Mach4 not starting
any idea's
Regards Ray
Hi
any idea's
Regards Ray
https://www.machsupport.com/forum/index.php?topic=31441.0 I know this was a previous topic about this problem but I cant find or search for it the search function is not working
Well I spent a hour or 2 and searched manually the forum for a post I knew had to be there and found the answer
Net.framework needs to be installed on the computer I installed that and we are all good
