Mach Discussion => General Mach Discussion => Topic started by: Trev133 on November 02, 2018, 05:14:08 AM
Hi Guys. This may sound a simple question to most of you but can anyone outline what I need to do to create a 2nd profile which I can set up as metric. Can I get a 2nd icon on the desktop?
Much Appreciated
If you go into your Mach3 folder then open (run) Mach3.exe that should then enable you to create a new profile, shortcut, etc.
Hi. Many Thanks for getting back. I think have managed to Clone the Mach3mill profile and called it Mach3IMP (see photo). How do I get it as an icon on desktop? I have right clicked and hit "create shortcut" but it takes me to realms of files. I'm obviously missing some step.
the new shortcut will be created in th same folder as the .xml file, ie c:\Mach3. Once the shortcut is created
cut and paste to the desktop.
Hi Craig. Thanks for your help yet again. See attached photos. When I create the shortcut and cut and paste I don't get an icon that opens a Mach3 file. When I click the icon on the desktop I get the data that is on 2nd photo. Any thoughts. Trevor
Sorry 1st photo
Much easier than fiddling with creating shortcuts in Mach3 folder and mooving it on Desktop:
* Right click on your desktop icon Mach3Mill, from popup select Copy.
* Right click on an empty space on desktop and select Paste. This will make a copy which can be renamed and modified.
* Right click on a freshly made copy and select Properties
* In Target field change 'Mach3Mill' to 'Mach3IMP' (from your screenshot I'm figuring that it is your new profile)
* Change to General tab just change the name of the shortcut.
Aply, OK
That's all :)
Brilliant. Got it. Worked 1st time. Really appreciate all your help guys.
Trevor
