Mach Discussion => Mach4 General Discussion => Topic started by: mcbride19 on October 11, 2018, 07:47:41 AM
After a long time with the engineer to find a solution to the problem, he sended to me an updated drivers that, now, control the spindle speed by the gcode command and the slider into the software
I hope it will help some users !
Hi mcbride19,
Thank you for sharing this information and the updated plugin.
Knowledge is powerful only when it's shared ;)
Hi
I have ordered a XHC controller and are just getting every thing ready thanks for yous post "I have down loaded the file
Can I ask is your machine running ok and working good ? what computer operating system are you using my controller is a USB connection and I am thinking of buying a new computer which will come with windows 10 do you know if that will work ok
Thanks Ray
Yes my CNC is working good it's a 3040 with 800w spindle(watercooled) with 4 axis.
I have the XHC Mk4 mach4 USB motherboard.
here is my CNC:
(https://i.ebayimg.com/images/g/5G0AAOSwI51ap2-s/s-l1600.jpg)
I'm working on windows 10 and windows 8.
Except the fact that it came with a "hacked" version of Mach3 I will say that it's a good product.
For a new computer to pilot your cnc you don't need to buy a big one(I mean 8 cores with 32 Go memory etc ...), a simple one is able to pilot the CNC, but you will need a power one to calculate the Gcode if you are doing complex milling(with a lot of path) or else the calculating time will be longer (of course).
