Mach Discussion => General Mach Discussion => Topic started by: hismaimai2000 on September 20, 2018, 02:21:11 AM
I would like to add a Home switch to my A axis and the easiest way to do it is to wire in series the X Home switch which is already wired to Pin 12 with the new A Home switch. Is there a problem with this setup or it has to be a separate wiring ?
that should work.
I always prefer one input per home switch if you have spare inputs.
