Mach Discussion => General Mach Discussion => Topic started by: Fusco96 on September 12, 2018, 05:48:51 AM
Hello
I have a USB mach3 board. Recently I have started facing the issue, that the Pul and Dir pins for the X, Y and Z axis are short on the board. Also the A axis pins are not short. Is this how it is supposed to be or is my board messed up.
Note: I am only using the X, Y and Z axis for my CNC
Thank You
how do you mean 'short on the board'?
They shouldn't be like that. Without manufacturers support who knows.
I have recommended to you before to buy a recognized brand....I do so again.
By short i mean that they are continuous. I tested it out with a multimeter. And as far as a different board goes, I am stuck with this one currently. If it turns out to be completely hopeless, then I will be moving onto a different board.
SO if we tell you it is completely hopeless, will you move onto a reliable board right now instead of fighting this one?
FYI, it is completely hopeless!
ROFLMAO
Mike
;D
Hi Fusco96,
I hope I din't drive you away with my sense of humor!
All kidding aside, having gone down the road of using some of the less desirable boards, we are trying to save you a lot of pain and time.
I am a big fan of the Hiconn, although some people balk at the price. I now have a Pokeys 57CNC which I like. There are others as well.
The theme here is to do your research first and then buy something that will give you what you want for years to come.
Mike
I think Fusco96 is made of tuff stuff but you were a bit hard on him Mike. :)
