Mach Discussion => General Mach Discussion => Topic started by: peter81 on August 27, 2018, 10:17:08 AM
Hello all,
I need quick help regarding suitable drive for this stepper motor - https://www.ebay.ie/itm/Nema-23-Stepper-Motor-Bipolar-2-0Nm-285oz-in-For-CNC-Schrittmotor-Steuerung-8mm/141860786801?hash=item21078fd271:g:0XsAAOSw44BYUMFq
Will this drive be ok?
https://www.aliexpress.com/item/3pcs-Updated-version-of-TB6600-StepperMotor-Driver-4A-9-42V-TTL-16-Micro-Step-CNC-1/32825754783.html?spm=2114.search0104.3.30.6d763ceclAQBZ0&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_5724015_10083_10618_5724315_10304_10307_10820_10301_10821_5724215_5724115_10059_5013715_100031_5725015_10103_5724915_10624_10623_10622_10621_10620_5013815-normal#cfs,searchweb201603_13,ppcSwitch_4&algo_expid=56431452-e949-435c-8aa6-8b53cd1a2ac7-4&algo_pvid=56431452-e949-435c-8aa6-8b53cd1a2ac7&priceBeautifyAB=0
Peter
Yes it will work but I think you’d do better to get an equivalent Leadshine drive. Still chinese but based on better technology and considered to be very good drives.
yes it will work, but buy some spares....they tend to blow up. They are based on a Toshiba IC and they are tender. Note the max voltage is only 42V.
As Gary has said Leadshine do better, the AM882 is very capable. 80V max
If you don't mind paying extra then look at Gecko drives, top quality.
Ok thanks very much for help.
Peter
