Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: John40131 on August 22, 2018, 02:05:51 PM
Hi, from a previous post I had problems with setting up a 2nd Parrallel port which I sorted but have a minor issue which hopefully someone may help.
I installed the second Parallel Card again with Port address 0xe880
Output Signal
Output Pin #1 Enabled Port #2 Pin #17
When I Check / Uncheck Active Low relay operates correctly.
Mist Settings
Port 1 address 0x378
Output Pin #3 Enabled Port #1 Pin #17
When Check/Uncheck Active Low relay operates
Fine so far.
If I then go into Diagnostics click Spindle Toggle both relays operate
Click Mist Toggle just mist relay operates
Similarly
If I select in MIDI ,
M3 Both relays operate
M4 Just the spindle relay
M5 Both off
M7 Mist relay operates
M8 None
M9 Mist Off
Also in Spindle setup in Ports and Pins I have spindle control checked and PWM, Relay Control on pin 1 for CW and CCW and mist on 3 and Flood 4, not sure what these pins mean
Update, If I uncheck "Use Spindle Motor Output " the relays are fine but I need spindle motor for PWM control.
So how is it that both relays operate with an M3 or Spindle Toggle, or should they.
Grateful for advise.
Regards John
Post a pic of the spindle tab and the output tab from ports and pins.
Well when I turned on computer and Mach 3 this morning it worked fine, it must has required a restart.
But I enclose copy as requested
Most grateful for help.
Regards John
Try again with attachments
Sorry just noticed that Spindle control not checked, problem returns but if I uncheck PWM control it works fine so its whatever the PWM controls is the problem.
Regards John
Think I solved, When I changed the Spindle setting in Motor Outputs to Port 2 and pin 17, I forgot to change the step and Dir ports on the same line to 2, that solved the problem.
Regards John
You need to know how your machine is setup (wired), to find out why it's doing that.
