Mach Discussion => Mach4 General Discussion => Topic started by: gorf23 on August 06, 2018, 09:19:58 AM
Title: mach4 and cambam ?
Post by: gorf23 on August 06, 2018, 09:19:58 AM
I have a gcode file I created with cambam and seem to have an problem with g83 and the Q word the code has many lines with g83 but only the first g83 line has the Q the rest don't
so mach4 it showing an error at the next g83 line no Q word.. it works ok with mach3 just not mach4 any suggestions?.
Thanks gary
Title: Re: mach4 and cambam ?
Post by: Cbyrdtopper on August 06, 2018, 09:26:09 AM
There has been a post about this very issue before.
http://www.machsupport.com/forum/index.php/topic,33845.0.html
Mach4 only requires G83 on the first line of the canned cycle and it probably requires a Q since that is the peck depth variable.
Post by: gorf23 on August 06, 2018, 11:33:12 AM
thanks that worked.
 I did a search before I posted but that message didn't pop up sorry..
Gary
Post by: Cbyrdtopper on August 06, 2018, 11:34:48 AM
No worries,
It should have popped up with the G83 search, but didn't.  I kind of knew what I was looking for though and was able to find it pretty quickly.
Glad you got it figured out!
