Mach Discussion => General Mach Discussion => Topic started by: Chelsey on August 02, 2018, 07:38:49 PM
Title: Mach3 problems
Post by: Chelsey on August 02, 2018, 07:38:49 PM
I have had Mach3 installed on 2 pc for awhile. The one in the house is a Vista pc I installed to do some prelim work. The other pc in my shop is a windows 7 pro that is also hokked up the my cnc router. I haven't used either in awhile and wanted to start again. When I tried to load Mach3 on the Vista machine, the shortcut was dead and I can't find the ese file anywhere on the pc. When I tried to load it on the windows 7 pro machine, the Artsoft logo appears and then the pc reboots. What's up with that?
Title: Re: Mach3 problems
Post by: joeaverage on August 02, 2018, 07:44:33 PM
not sure about your development PC but the machine PC sounds like a recent Window 7 update
has caused a fault. There have been a lot of posts about it over the last couple of months.
I think there is a patched version of .062 which solves it. The machine PC should be kept off the internet
so it cant update, the last three monthly updates have caused Mach to reboot as you describe.
Post by: Chelsey on August 02, 2018, 07:50:23 PM
Thanks for the information.  I'll try to find the patch.
Post by: joeaverage on August 02, 2018, 08:04:44 PM
I may have lead you astray....there is a patch .062 to cure a problem with Window 10 updates.
There are issues with Windows 7 updates also, it may be neccessary to manually remove the updates.
A search should reveal the thread or threads that discuss it.
This deals with Window 10 updates:
http://www.machsupport.com/forum/index.php/topic,37291.0.html (http://www.machsupport.com/forum/index.php/topic,37291.0.html)
This mentions the Windows 7 updates:
http://www.machsupport.com/forum/index.php/topic,37670.msg257402.html#msg257402 (http://www.machsupport.com/forum/index.php/topic,37670.msg257402.html#msg257402)
Check with Byranna, she seems to be keeping an eye on developments.
Title: Mach3 and Windows 7 problems
Post by: Chelsey on August 04, 2018, 10:15:38 AM
I haven't used Mach3 in awhile. Tried to start it up and computer reboots. Asked on this forum and was told about Windows update problems. I tried to uninstall them. One went away very easily, another would not go away. I did a system restore to April 2018. Problem still exists. Now I'm told I may have to purchase a $110.00 part to make it work. This part "MIGHT" fix the problem. Anyone have any more ideas? I can't keep throwing money at a problem.
Post by: Tweakie.CNC on August 04, 2018, 10:30:07 AM
I don't know if this is any help but...
For Mach3 I use WinXP and my CNC machines are operated by dedicated PC's which are not connected to the internet or receiving updates.
Post by: Chelsey on August 04, 2018, 10:43:24 AM
What does that mean? I mentioned I have Windows 7 right? I don't understand your answer.
Post by: ger21 on August 04, 2018, 12:38:26 PM
His answer is don't use Windows 7.
Post by: Chelsey on August 04, 2018, 03:06:32 PM
If you don't know how to help, I see no reason to reply at all. Just sayin'
Post by: ger21 on August 04, 2018, 04:35:20 PM
You don't have a lot of options here, as Mach3 is basically a 10 year old, unsupported program.
You could switch to Windows 10, and get a motion controller, but there's no guarantee that Microsoft won't break it again.
Or you can run Windows XP.
Or you can leave Mach3 behind and move onto something more modern, and well supported.
Post by: Chelsey on August 04, 2018, 05:50:07 PM
Thanks. I guess I purchased the software too late. I only got a short time with it before I was kicked to the curb. Now I have a licensed piece of worthless software. I didn't realize the software wasn't backed up anymore. My bad. Thanks again for your replies.
Post by: joeaverage on August 04, 2018, 06:05:51 PM
Hi Chelsey,
its not all doom and gloom.....Mach3 still works as well as it always did PROVIDED you keep it away from a PC which
gets Microsoft updates.
As you know Microsoft does not support XP anymore and consequently there are no updates for it....and for Mach users that is a good thing.
You can of course use Windows 7 but Microsoft do update that. You'll have to keep the PC off the internet or otherwise disable Windows updates.
The Windows 7 updates which are causing you grief affect the parallel port driver only. If you use an external motion controller like a SmoothStepper
then your installation would run fine. I understand that you don't want to spend any money but maybe its just too damn bad. I for a long time
persevered with the parallel port before I bought a SmoothStepper. I am delighted with it...it has bought so many advantages that I didn't realize
I was missing. A SmoothStepper is about $190US, if you are an Aussie then there a guy in Melbourne selling them, and how much is that relative to the
total cost of your CNC installation?. I've spent about $10,000 making my mill, $190US to get it to go right.....no brainer for me!
Post by: Chelsey on August 05, 2018, 08:02:59 AM
Thanks for your insight. I now have a better understanding of whats going on. Sorry if I seemed rude, it was not my intention.
Post by: amex on August 11, 2018, 08:35:18 AM
Hi Everyone,
Is here anyone who can help me in the Mach3 settings please?
I have a Novosun USB 4 Axis controller+ Tb6600 4A 40V Stepper Drivers and Nema23 stepper motors.
Basically it is a MiniMill Machine.
Please help me, how I need configure the Mach3, because the machine doesn't work well.
Thanks for all.
Post by: joeaverage on August 11, 2018, 02:20:54 PM
you'll have to get the pin assignments for your controller from the manufacturer.
The manufacturer is Chinese and sometimes they are exceptionally bad at providing manuals or support for their boards.
You'll just have to keep hammering at them until they do so. Those Novosun boards are common enough I think you'll find some info
on them.
Failing that buy a US or European made controller, they work as expected and advertised and the companies support their products.
Post by: platinumrob on August 12, 2018, 07:12:01 AM
Post by: platinumrob on August 12, 2018, 07:14:30 AM
I don't know if this is linked but I have the latest version of Windows 7 which I have just installed on an old PC I have because I'm new to Mach3 and want to connect it to a chinese USB CNC router. I have a 32bit PC with Windows 7 ultimate and after downloading and trying to open Mach3 I get an error message 'Unable to open ProbeDiag.dat Error =5' then 'Access to LastErrors.text denied'. On End Session prompt there is 'Error found Art Code 20070911 Attempt recovery' message. Consequently I am unable to open the software. Any advice please as to what is wrong?
Post by: joeaverage on August 12, 2018, 10:23:49 AM
the Windows 7 update that was causing grief for Mach3 users occurred for those users with a parallel port. Whenever Mach attempted to
engage the parallel port driver the PC would re-boot.
Your description of the fault is different. I would in the first instance delete the motion control plugin from Machs Plugins folder
and cause Mach to try to engage the parallel port driver instead. Even if the parallel port is not there......it will tell you if the fault is related
to the plugin.
