Mach Discussion => General Mach Discussion => Topic started by: TroxKor on July 31, 2018, 02:45:30 AM
Title: Mach3 pin 15 Always active
Post by: TroxKor on July 31, 2018, 02:45:30 AM
I tried a few searches so as to not double up posts but didn't find a post that helped.
Recently bought a X2 converted to CNC from a guy that has used it for years. I need a probe in my machine, and this is where my trouble starts. Pin 15 is always showing as triggered. I changed cables, break out boards, switches, all of it but PC components.
Anyone have an idea what might be the cause? Do I need to get a whole new PC?
Title: Re: Mach3 pin 15 Always active
Post by: Tweakie.CNC on July 31, 2018, 03:24:52 AM
I presume you have Port#1 Pin 15 set as the Probe Input in Ports & Pins. Have you tried changing the Active Low state ?
Post by: TroxKor on August 01, 2018, 12:03:42 AM
Yea, I changed all of the setting to see what would happen, it would either move to always triggered or never triggered. I changed it from the probe to a limit switch that was working fine. Same results. I changed the break out board, same results. Really at a loss. I can work around it by doubling up a limit switch, just not ideal.
Post by: Tweakie.CNC on August 01, 2018, 12:27:33 AM
If you have done all the tests then it sounds like Pin 15 from the Parallel Port is dead.
Either another PC or perhaps fit a new PCI Parallel Port card (5 Volt version - this thread refers; http://www.machsupport.com/forum/index.php/topic,34848.msg239910.html#msg239910 )
