Mach Discussion => General Mach Discussion => Topic started by: stringkilla on March 25, 2006, 07:38:39 AM
Hi guys. I have tried to use the G56 fixture area while setting up to run my first part. Then I get back to the main screen and try to posititon it on the screen that shop my table, that's when it hits the fan. As soon as I try to move in that area with my mouse it go haywire, losses it's orientation and goes rotational on me. Any input as to what I'm doing wrong here. Oh the machine drilled a hole deep into the table and tried to move from deep in the substrate..
can you get it to run if you use the G54 offset?
Brian, I I've been so busy with a room repaint I haven't had time to try. I am not at all versed in cam at all I believe some of me trouble lies there but I should be able to get to work.
