Third party software and hardware support forums. => SmoothStepper USB => Topic started by: Mr. Toad on June 18, 2018, 11:57:46 AM
Title: Ess Reset Velocity N. Disabling mach
Post by: Mr. Toad on June 18, 2018, 11:57:46 AM
I built this cnc router and tried to fire it up to drill a series of holes to screw the spoil board to the table. I am using mach4 (the trial version) ESS, the new version and V Carve Pro. A couple of question here: I did a little drawing to lay out the holes, tool path etc. and saved the tool path, when a tool path is saved what file ext. does it save as? Mine saved as a txt. I used that. When I ran that I got a message, "ESS Reset Velocity N. Disabling Mach". What does that mean?
Title: Re: Ess Reset Velocity N. Disabling mach
Post by: Tweakie.CNC on June 19, 2018, 01:07:03 AM
Hi Mr.Toad,
To avoid duplication this topic is already being dealt with by Andy (the expert) on the Warp9 forum;  https://www.warp9td.com/index.php/kunena/7-general-discussion/7576-woodworker-needs-help?start=36
