Mach Discussion => General Mach Discussion => Topic started by: bhauck68 on June 12, 2018, 11:39:40 AM
I've run into an issue with a laser welding station that I've designed with Mach3 and SS board and can't seem to find the cause of a feed rate error.
I've found that I need to use a g-code feed rate 4x what the actual feed rate is. For example, If I want 600mm/min I have to enter F2400 instead of F600.
Attached is my XML if anyone is able to help resolve the issue it would be great.
Brian
Is the FRo set to 25%?
Nope - its set to 100%
can you confirm the accuracy of your steps per unit values by issuing this MDI:
G0 X0
X300
Does the X axis move 300mm?
My system only has 100mm stages so I entered X50 and it moved the corresponding 50mm. So correct distance is traveled.
well that narrows things down and starts to look like a more mysterious problem.
Clearly you have the steps per unit right for otherwise your X50 move would not have moved 50mm.
Could it be that your controller can't produce pulses fast enough to go at your maximum desired speed?
Are you using a parallel port and if so what kernel frequency have you set? What are your Step per Unit values?
With those numbers we can work out what the potential best speed the controller can drive your machine, maybe its out of whack somehow.
Craig,
I've got a smooth stepper control board. I've got the kernal speed set to 100khz but have tried 25khz with no change. The steps per unit (mm) is set to 200 as I'm using a teknic clearpath motor that is setup for 1000 pulses per rev and the linear leadscrew pitch is 5mm/rev.
Brian
the smoothstepper should be any amount fast enough. Despite having a kernel speed of only 25kHz
even that would put the max speed at:
(25,000 / 200) * 60 =7500 mm/min, ie plenty fast.
Is it possible that you have some setting within the Clearpath which limits the speed? What model?
craig,
delayed response... but I looked at the teknic settings and don't see anything that would be impacting the speed. I'm using the step and direction clearpath motor. Just for the hell of it, I doubled the input resolution and doubled the Mach3 motor tuning (steps per). As expected this didn't impact my feed rate (still 4x slower than should be) and I'm still traveling the correct distances.
I'm sure there is a setting somewhere that I have set incorrectly but I just don't know what it could be...
ok so I figured something out. All this time I've been doing multi-axis moves. When I did a single axis the feed rate is correct. When I take out the rotary 4th axis and do an XYZ move then I have speeds that are 1/3 slower that expected not 4x. So I'm not a g-code expert but is the F value per axis or is it the RMS value for all the axis?
I've got my rotary set for 53.333 steps/degree and so I think that might be the cause for the significant slowing of the other axis???
I think you are onto it.
When a multi axised move is made they all move at such a velocity to arrive at the right place at the same time. If one axis is slow all the others will
slow to match it.
The F word applies to all axes. If how ever you specify F=5000 but an axis motor tuning specifies a maximum velocity of 2500, the 2500 limit will apply to that axis.
You may have your steps per unit value for your rotary axis at 53.333 but that's the steps per degree, so for one revolution that would be 19200 steps per rev.
If you have an F word of 2500, expecting a federate of 2500 mm per minute you will be disappointed because at that rate your rotary axis will turn only 46.87 degrees
in one minute. If you require it to turn one revolution then it will take over 7 minutes and the linear axes will slow so that they arrive at their anticipated endpoint at that
time.
