Mach Discussion => General Mach Discussion => Topic started by: hopeyeu on May 06, 2018, 10:18:47 PM
Why should persistent jogging be so mysterious?
I can't jog the machine after stopping it in the middle of a run. I was able to do it; now I can't anymore.
The code has not changed, but the config has. I went from v68 to v66 because it was suggested that the 66 is a better version.
I had this issue before I changed versions of Mach 3. The keyboard does not do it, nor does the virtual pendant. I am stuck.
Hope
There have been many problems reported with version .066 and as a result version .062 is now the preferred choice.
Your best bet would be to roll back to your previous version that worked the way you liked.
