Mach Discussion => General Mach Discussion => Topic started by: Prolightman on March 24, 2006, 05:56:17 PM
Title: NOOB question
Post by: Prolightman on March 24, 2006, 05:56:17 PM
I did the optimize setup to run mach 3
it says drivers intsalled
did drivertest I get no waveform test says mach 3 is now in control
before I start wiring and config these software is this right
I am running demo version on a dual xeon HT 2.2 ghz I set affinity to the first 2 processors
so the softs would only use 1 cpu
I have been using kellyware with very good results just lookn for better control
Title: Re: NOOB question
Post by: Brian Barker on March 24, 2006, 07:52:48 PM
I can't tell you much about a dual processor but I think they will not work...
