Mach Discussion => General Mach Discussion => Topic started by: CX15 on April 14, 2018, 04:35:03 AM
Title: GoTo Zero not working
Post by: CX15 on April 14, 2018, 04:35:03 AM
Hi All.
My new machine is up and running, but there's a few niggles :-(
When I hit GOTO ZERO in Mach3 the steppers on X and Y scream and although there's some movement, the spindle does not move to the correct position.
Z-axis behaves correctly.
Motor tuning (as per manufacturer) as follows:
Steps per: 320
Velocity: 4000
Accel: 300
Step Pulse: 0
Dir Pulse: 0
If I jog the X/Y axis using computer arrow keys, the unit moves smoothly and without problems at 4000mm per minute.
When I use "Ref All Home" function, it also moves smoothly and without problems.
When I change the Velocity down to 1000 things get "slightly" better.
The unit does move back to zero position, but it does it in a pulsing movement in stead of a smooth movement.
But this does not really solve the problem, as everything is very slow like this.
With some experimenting I found some other interesting behaviour as well:
When I execute this command
Code: [Select]
G0 X0 Y0
Same problem: screaming steppers, pulsing movement.
But if I execute this:
Code: [Select]
M03 S15000
G0 X0 Y0
the machine works perfectly fine (smooth movement). I dont understand why turning the spindle on makes the G0 command work differently.
I'm new to Mach3 and GCode, so I have no idea if this is normal behaviour, the CNC machine or Mach3 being the problem.
Any insights will be greatly appreciated.
Title: Re: GoTo Zero not working
Post by: joeaverage on April 14, 2018, 02:15:02 PM
That's the steppers having stalled. You need to reduce the speed/acceleration until they are reliable OR increase the voltage of the power supply and drivers so they can go faster OR
replace the steppers and/or drivers with more capable units.
Post by: CX15 on April 15, 2018, 03:32:31 AM
Hi Craig
I dont think the speed is set too high.
As I explained above: Jogging works perfect. Ref All Home works perfect and a G0 (after a M3) also works perfect.
No stalling, no screamingm just smooth movement at the defined max speed.
It's only the Go To Zero function that creates the problem
Post by: joeaverage on April 15, 2018, 03:44:17 AM
jogging is seldom at the fastest possible rate. It may be that your motors can jog at 50% of max but fail at 100%.
Screaming steppers have stalled. It is indicative that you have the speed too high for the steppers/drives/power supply, it is not a normal condition for Mach3.
Post by: Tweakie.CNC on April 15, 2018, 03:57:26 AM
As Craig has said your Velocity / Acceleration settings are set too high for your machine as it stands.
Just a guess but what I think you are finding here is a Mach3 peculiarity or limitation relating to the blended axis velocity of the Go To Zero function.
Post by: joeaverage on April 15, 2018, 04:07:28 AM
may I suggest slowing it way way WAY down until it works properly and THEN start to speed it up until you find the limits.
All we know for sure at the moment is that you are trying to go too fast....by how much we don't know yet and wont until you slow it down enough to find the limits
of performance. Then it appropriate to ask 'is this right...or is there some fault?'
Try speed of 500 and an accel of 100.
Keep upping the accel until it starts missing steps or stalling, then back it off 25% Then work on increasing speed until a fault occurs.
Note you need to use G0 MDI commands so that you are testing the same thing...jogging is not scientific enough to give you useful comparisons.
Post by: joeaverage on April 15, 2018, 04:38:21 AM
thinking also about the situation you describe where it seems to work if the spindle is running but plays up when the spindle isn't running.
You're right it shouldn't make any difference.
Does the power supply run both the spindle and the stepper drivers? I suspect it does.
Is the power supply a switching supply or analogue, I'm guessing a switching supply?
My guess is that the load on the power supply with the spindle running is sufficient to somewhat 'quiet' the switching supply such that the stepper drivers work better.
If that's the case you have a crap power supply, do yourself a favour and get a kick-arse analogue supply, they work so much better and so much more forgiving.
Post by: CX15 on April 15, 2018, 04:43:42 AM
Thanks Craig
I will investigate your suggestion.
However, in my tests the spindle was actually NOT on (VFD is switched off).
But just the fact that there was a M3 command seemed to make the difference.
I also tested the speed and when I use jogging (keyboard arrows), the gantry moves at the dialled in max speed (4000mm per minute).
Post by: joeaverage on April 15, 2018, 04:50:01 AM
well can rule out some sort of power supply interference.
I cant think of any reason that an M3 command would make any difference to a subsequent G0 move.
Post by: CX15 on April 15, 2018, 04:53:50 AM
The M3 also makes a difference to a subsequent G1 command
This
Code: [Select]
M3
G1 X0 Y0 F1000
works as expected. Roughly 1/4 speed and smooth movement to 0,0.
But if I just run this alone:
Code: [Select]
G1 X0 Y0 F1000
The movement is pulsating.
Post by: joeaverage on April 15, 2018, 05:02:48 AM
still can't think of anything that would tie them together.
I'm thinking you may have a bad case of midband resonance which can and does produce some wildly unpredictable results.
What stepper drivers are you using?
What microstepping regimen are you using?
What power supply, voltage and type, are you using for the steppers?
Post by: joeaverage on April 15, 2018, 05:09:02 AM
never thought to ask are you using a parallel port?
Can you post a screen shot of the DriverTest.exe page?
Post by: CX15 on April 15, 2018, 05:21:07 AM
USB connection.
It's a Chinese Special, so I'll have to tear it apart to see what's inside I guess.
Post by: GeorgS on October 31, 2021, 07:27:22 AM
I have the same behavior.
All movements without M3 Spindle command lead to interrupted movements. Same for the "gotozero" button.
strange.. did anyone solve this issue meanwhile?
Thanks!
Georg
Post by: CX15 on October 31, 2021, 08:02:09 AM
Hi George
I never resolved this issue. Till today its doing the same.
I'm chalking it up to cheap Chinese driver🤷
Post by: CX15 on October 31, 2021, 08:02:34 AM
What machine do you have
Post by: GeorgS on October 31, 2021, 08:38:06 AM
thanks for your reply!
I have an acctec 6012 with delta servo motors and the newest XHC Mach3 motion card. I guess it's a problem of the motion card.
I have an ethernet AXBB-E controller from cncdrive, but I'm not sure yet if it's worth to install. theoretically just wiring, but you know, inc. troubleshooting e.t.c it may take some days...
Georg
Post by: GeorgS on October 31, 2021, 03:56:24 PM
it also seems to be impossible to run the verify axis script with the xhc motion controller.
( to check the machine for accuracy/ step losses)
Post by: GeorgS on November 01, 2021, 04:17:54 PM
I tested another computer, now it works smooth.
changing the output settings to the values as set in the factory file from XHC also helped to improve the behavior on the old computer....
