Mach Discussion => General Mach Discussion => Topic started by: sawmill on July 14, 2007, 12:52:10 PM
is there any way to have tabs short of manualy editing the gcode ?
i tried creating a dxf with 2 layers and the second layer is interupted for tabs, but when i clean up the image in lazycam the extra layer goes away. even if i have duplicated lines off.
i have lazycam pro, and its great, but i could seee being able to copy a chain and drop it down for tabs being very usefull
thanks
dan
This is something that I have to add in Lcam and as you can see it is not as simple as you think :(
I hope to get started on it soon as there is an OEM that needs it for a bunch of machines that need to ship :) Nice to have the pressure to drive you to work all night!
Brian
hmm , ok
i thought you might be able to do like a shape file, only on the bottom layer , that way we could place a rectangle with the width of our choice for the tab width
thanks
dan
