Mach Discussion => General Mach Discussion => Topic started by: Johnansaro on March 25, 2018, 11:38:41 AM
Hi there
I am trying to Install a CC Auto tool changer Spindle Model (MHS72-7512FSF).
What I like to know is What hard ware do I need to have? , and what steps do I need to take in order to do so?
Please be noted that this my first attempt to install a Spindle with ATC, I installed a Manual spindle before, BUT ATC I am a Newbie.
Regards
Jhonansaro
-some toolholdes
-a solinoid valve for the tool clamp
-a macro
-a couple of other things to get everything fixed
- some luck
Hi TPS
Thanks for the reply.
I sort of know about them.
But could you explain with a little more detail.
I know that there is a Start and stop Macro, I already have the "M6Start" file, Do i also need a stop Macro? or is it in my Start macro already?
also I think I need to add some Tab pages to my Mach3, Do you have the links for them?
My Spindle should have the required Solenoid, I am planning to use CC (Chinese) or HSD (Italian)
Regards
Jhonansaro
this is a Standard Start macro. you will need a machine specific one, like i have done here:
http://www.machsupport.com/forum/index.php/topic,36417.0.html
BTW the search function of the Forum is not so hard to understand ;)
the stop macro is only to return where the tool Change started.
ok the only Thing, i think, is that you please read a Little bit more about basic's of ATC
that is a Point YOU have to figure out.
