Mach Discussion => Mach4 General Discussion => Topic started by: Analias on March 17, 2018, 01:37:56 PM
Title: Notebook tab reordering - could it be any more painful?
Post by: Analias on March 17, 2018, 01:37:56 PM
If anyone has any enlightenment to share on how to reorder tabs in a notebook, please share with me.
I have tried dragging tabs in the UI tree to reorder - crashes Mach4GUI.
I have tried dragging tabs in screen layout itself - does nothing.
I have exported tabs and tried re-importing them - Mach4GUI spins for ever and eventually crashes.
I have tried cut-n-pasting (which works with other UI components) back into the notebook - does nothing.
I have tried deleting and then re-pasting back into the notebook - worst yet, deletes the tab and it's contents, but paste is disabled.
It's been three years, please give the screen editor a bit of love and attention. The development tools are the first thing integrators will look once they decide the motion engine is worth investing in. This is so frustrating.
Title: Re: Notebook tab reordering - could it be any more painful?
Post by: Analias on March 17, 2018, 01:47:02 PM
Just had an idea - Turn the screen editor into a Lua tool and provide the source with Mach4. Then it can be modified, problems fixed, features added by the community.
Just an idea.
Post by: Cbyrdtopper on March 19, 2018, 07:21:46 AM
I moved the tabs in the design tree.  It doesn't work perfect.  But I was able to get them in the order I liked by moving them there.
Post by: django013 on March 21, 2018, 12:39:05 AM
Sure screeneditor has several shortcomings/issues on big edit sessions.
What really helps, is the simple format of the screen file itself.
The screen-file is a zip-archive with a screen.xml at root level.
That screen.xml is a simple text file, so you can extract it and use any text-editor or xml-editor.
If you use a simple text editor, you're responsible on your own for pattern matching. But it is not difficult at all.
I use gvim on linux systems with good result.
Tab-reordering is just a matter of moving a number of rows - not a challenge :)
If you take care for the xml-patterns, you can change anything with the text-editor, which makes big changes fast and easy.
When you're done put the xml-file back into the screen-ziparchive and start mach4 with that file.
If you did no mistake, anything works fine.
Cheers Reinhard
Post by: arhimedoffs on March 24, 2018, 03:04:45 AM
I also simple edit XML file in *.set archive. And all if fine. I think this feature has not demand. Main problem - in standard sets there is binding to tab number )
