Mach Discussion => General Mach Discussion => Topic started by: Jacko on July 13, 2007, 04:27:33 AM
I made a router using "mach 3 mill" and then scrapped that and converted my lathe with the bits i salvaged. I am now using "mach 3 turn" to run my lathe. Every thing is working fine except that i cant jog the x axis. The axis and dro move ok when i jog z but nothing moves when i try to jog the x axis, not even the dro. The lathe is working fine and runs programs ok. Have i had a dodgy download or do i need to configure something. The office computer that i originally download mach onto is the same. ie only the z axis will jog.
thanks in advance
jacko
With the Mach3 Turn screens you can only jog on the Manual screen AND You have to have the Jogging on :(
Hope that helps..
Brian
i have since downloaded the latest version and everything now works fine.
thanks
jacko
