Mach Discussion => Mach4 General Discussion => Topic started by: thespindoctor on March 14, 2018, 04:09:51 PM
I had a great setup with several meters displaying voltages from 4 analog inputs. I was changing the ticks and max value on one of the meters and they all stopped working. Then I reverted back to the original settings but no matter what I do, the meters are silent. However, one meter showing an average/sec of voltage is working fine. The registers for these analog inputs show the proper voltages. I have the code in the PLC script and was wondering "are if then statements in the PLC a problem"? Would it be better to do this in the signal script? Does the signal script scan just like the PLC so I could basically use the same code there?
http://www.machsupport.com/forum/index.php/topic,36590.msg251089.html#msg251089 (http://www.machsupport.com/forum/index.php/topic,36590.msg251089.html#msg251089)
Might help.
Yes that was my posting to set this all up but now it has stopped working for no apparent reason...
Fixed it! Just during a copy the meter names changed... escy fix difficukt to see
