Mach Discussion => General Mach Discussion => Topic started by: Benjammann on March 11, 2018, 08:09:14 AM
I finally got a triple edge finder and wired it up (somehow) correctly on the first try. (I think)
Then I got the hoss screenset which replaces the tool offset screen with the automated edge finder buttons.
When I try to use one of the routines, the Z axis moves down and touches the plate, then seems to back off a bit, then immediately throws an error that "plate is grounded" and moves into position to do the X edge find and stops.
I can make it go through the whole routine by simulating a Z by touching the plate to the mill then quickly taking it away. Then the error will not be produced and it runs the X Y edge finds.
I'm on a Taig mill using software limits.
It just seems to be doing some sort of double touch where it checks to see if it's grounded and it's still grounded because it just touched off and hasn't cleared out yet.
Any ideas?
Here's the code for the button:
Rem Probe Left
XNew = GetDro(0) - 3 'probe to current position - 3 inches
Code "G31 X" &XNew
While IsMoving() 'wait for prob move to complete
Wend
XNew = GetVar(2000) 'read the touch point
Rem move back To the hit point incase there was an overshoot
Code "G90 G0 Z.500"
Code "G90 G0 X" &XNew
Code "G91 X-" &CurrentToolDiameter/2 'moves the probe half the tool diameter to center on edge
While IsMoving ()
Wend
Call SetDro (0,0.000)
Code "G4 P0.25"
Code "G91 G0 X-.200 Y1.0"
Code "G90 G0 Z-.200"
Code "F" &CurrentFeed 'restore original feed rate
End If
Rem VBScript For probing In the Y- direction
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
Call ProbeGrounded()
Exit Sub
Else
Code "G4 P1" 'Pause 1 second to give time to position probe plate
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
Code "F4" 'Slow feedrate to 4 ipm
Rem Probe up
YNew = GetDro(1) - 3 'move to current y position + 3 inches
Code "G31 Y" &YNew
While IsMoving() 'wait for the move to finish
Wend
YNew = GetVar(2001) 'read the touch point
Code "G90 G0 Z.500"
Code "G90 G0 Y" &YNew
Code "G91 Y-" &CurrentToolDiameter/2 'moves the probe half the tool diameter to center on edge
While IsMoving ()
Wend
Call SetDro (1,0.000)
Code "G4 P0.25"
Code "G90 G0 X0.0"
Code "(X, Y, and Z axis' are now zeroed)"
Call ReturnG90G91State()
Exit Sub
End If
Sub ProbeGrounded()
Code "(Probe plate is grounded, check connection and try again)"
End Sub
Sub ReturnG90G91State()
If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
End If
If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
Code "G0"
End If
End Sub
copy your code into VB Scripter window.
use the ||> step button and step through the code,
than you will see exactly when the error occurs.
I’ve followed your suggestion and tried all morning to edit the script in every possible way I can imagine to get ride of the ground error. Nothing yet. Any other things I can try? The wiring seems to be good when I test the connection.
but if you go to diagnostic Screen you can see the digitize LED working,
Off if your probe is free, ON if you touch your probe to te plate ?
Yes, when I go to diagnostics there are no lights on until I touch the plate to the probe. Also, when I run the auto-zero, I can make it work by manually touching the plate to Z and then quickly removing it. That's the only way it will continue to probe X and Y.
I put a two-second pause between every line of code and still It does not work. I also tried commenting out as much code as possible to isolate the issue. Every time after It touches the plate, the next move causes the plate grounding error.
the Basic code is still the same you posted at the beginning ?
because in this code is no Z probe only:
X and Y.
make a shot description what the code should do.
Looks like I made an error copying the above code. I've posted the correct code below.
The code is supposed to automatically zero the XYZ axis by first probing down to the top of the plate, then jogs over to find the X, then the Y. I can get it to work by manually touching the plate to the probe, but any time the plate is resting on the wood or aluminum material a grounding error occurs. I think it's because I can quickly pull the plate away and some sort of double signal is not sent that causes the error.
Here is the code that causes the error:
Rem Auto corner finding X-Y-Z-(button3) With tool diameter Input
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(43) 'gets the current tool diameter
If GetOemLed (825)<>0 Then 'Check to see if the probe is already grounded or faulty
Exit Sub
Else
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P2" ' two second delay
Code "G90 G31 Z-1.0 F5" 'Z goes down a max of 1.0 at 5IPM
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2,0.000)
Code "G4 P0.25" 'Pause for Dro to update.
Code "G90 G0 Z.500" 'retract Z to .500 inch
Code "G91 G0 Y-.100 X1.0"
Code "F" &CurrentFeed 'Returns to prior feed rate
End If
Rem VBScript For probing In the x- direction
If GetOemLed (825)<>0 Then 'May need to use =0 if it errors
Call ProbeGrounded() 'Check to see if the probe is already grounded or faulty
Exit Sub
Else
Code "F4"
Rem Probe Left
Code "G31 X" &XNew
Wend
Code "G90 G0 Z.500"
While IsMoving ()
Wend
Code "G4 P0.25"
End If
Exit Sub
Else
Rem Probe up
Code "G31 Y" &YNew
Wend
Code "G90 G0 Z.500"
While IsMoving ()
Wend
Code "G4 P0.25"
Code "G90 G0 X0.0"
Exit Sub
End If
Sub ProbeGrounded()
End Sub
Code "G91"
End If
Code "G0"
End If
End Sub
are you working in metric or imperial?
added a few while ismoving see if this helps
Exit Sub
Else
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
End If
Exit Sub
Else
Code "F4"
Rem Probe Left
Code "G31 X" &XNew
Wend
Code "G90 G0 Z.500"
While IsMoving ()
Wend
Code "G4 P0.25"
While IsMoving ()
Wend
End If
Exit Sub
Else
Rem Probe up
Code "G31 Y" &YNew
Wend
Code "G90 G0 Z.500"
While IsMoving ()
Wend
Code "G4 P0.25"
Code "G90 G0 X0.0"
Exit Sub
End If
Sub ProbeGrounded()
End Sub
Code "G91"
End If
Code "G0"
End If
End Sub
Thanks so much! I'll try this as soon as I get home tonight. I'm working in Imperial (Inches)
EDIT: Although in looking at the code you posted, it doesn't seem you changed anything above my problem area. I get the error when Z retracts to .5" near the beginning...
i guess i mean this code aeria:
While IsMoving ()
Wend
End If
Exit Sub
Else
and specialy here i added a while ismoving() to wait for movement finished before the checking of probe is grounded
maybe this
y movement is to small, to go down with z axis
this code is for right upper Corner?
I think it stops before it gets that far, but I'll give it a shot this evening.
Yes because my table travel is short so I have to locate in the middle of a part. But whenever I get it working ill take this code and transfer it to the other buttons for other corners.
Hey, Thanks for all your help. This was the solution!
While IsMoving ()
Wend
End If
hi .. i am sort of new on this..
just asking and learning....
i dont know much of these codes ...but i need a script for auto zeroing my mach3
could you post the entire script?
thanks in advance
