Mach Discussion => Mach4 General Discussion => Mach4 Toolbox => Topic started by: jcoldon on March 04, 2018, 11:06:52 AM
can some one tell me how do I add a tool to my plasma mach 4 I running a vitalsystem arch pro screen I want to add an engraver. I see there are tools would I use them and setup the offsets. program a button. and assign an mcode to use in sheet cam. im not sure thanks jeff c
im happy to report my vital system hilcon controller and arch pro plasma screen can now change tools . with the m6 command thanks to Cbyrdtopper who did the code I will say I learned a lot
of how things work in mach 4 now when activating a code in sheet cam my x y z now responds to the tool offset triggers an out put and has a button for over ride
and works fine now I have the ability to have 99 tools don't need that many in plasma lol
It's been a while on this thread, but can you post the code that I sent you? I don't remember how I helped you out and someone else is asking about this as well.
Thanks!
