Mach Discussion => Mach4 General Discussion => Topic started by: swood1 on March 01, 2018, 04:26:40 AM
Hi all,
I had problems with my spindle drive which ended up being the transformer for the drive which has now been replaced. Prior to this I was trying all kinds within Mach4 in the hope that it was a software setting and not the drive. Now when I start the spindle it instantly stops again. Can anyone give me any pointers on what to look for to resolve this?
Regards
Steven
Do you use a PMDX-107 for the spindle?
Yes I am using a PMDX-107 for spindle. I had it running before the transformer on the spindle drive packed up.
https://warp9td.com/index.php/kunena/7-general-discussion/6442-mach3-ess-pwm-spindle-problem
https://www.pmdx.com/PMDX-Forums/index.php?topic=305.0
Grab a cup of coffee! Not sure any of this is relevant to your situation.
Contact Steve Stallings via email, he WILL help you.
Tom
how about fitting a voltmeter on the output of the 107 to see if the analogue voltage is persistant.
If it is it suggests that the VFD is faulting out.
