Mach Discussion => General Mach Discussion => Topic started by: Gianfranco Fazzini on July 10, 2007, 02:57:56 AM
I'm a new user.
I've tested a macro that use the Serial Port to comunicate with my remote panel build up around a PIC18F4620 by Microchip.
To do this I've used :
Set objCOM = CreateObject ("MSCOMMLib.MSComm", "MSCommEvent_")
Everything works fine until I save it as MacroPump.m1s. At this point I get always an error "Coninitialization".
After same test I thing I've found out these:
1.If in MacroPump.m1s there is any kind of CreateObject this error comes out alwasy.
2.If I put the source in a macro like M101.m1s and then I call it by MacroPump.m1s then everythings looks to work well but I cannot run any other macro.
3.If I use the calls to the API to comunicate with the serial port and I put everything into the macropump.m1s that it looks to work fine but to use the API is little more complex then createobject.
4.If I use SendFifo/GetFifoEntry the RS232 has to much delaysometimes and something like Jog/buttons doesn't work fine.
Someone can help me about this COINITIALIZATION ERROR in MacroPump?
Sorry for my poor english.
This is my Source Code MACROPUMP.M1S:
Option Explicit
Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long)
Dim objCOM As Object
Dim RS232_ResponseOK As Boolean
Dim vbCrLf As String
Dim RS232_Response_Command As String
Dim RS232_Response_Char As String
Dim Loop_Exit As Boolean
Sub Main ()
Message "Remote Panel..."
Call COM_Open
Call COM_Out_Line("L0101Remote Panel")
Call COM_Clean
Call COM_Out_Line("S0")
Loop_Exit=False
RS232_Response_Char=""
RS232_Response_Command=""
Message "Remote Panel Start at " & Now
Do
If Loop_Exit Then Exit Do
If objCOM.InBufferCount>0 Then
'Dati in arrivo
RS232_Response_Char=objCOM.Input
RS232_Response_Command=RS232_Response_Command & RS232_Response_Char
Else
Sleep 10
End If
If RS232_Response_Char=Chr(10) Then
'Comando da Elaborare
Message RS232_Response_Command
Call PANEL_Command_Parse (RS232_Response_Command)
End If
Loop
Call COM_Out_Line("O1=0")
Message "End " & Now
Call DoOEMButton(334)
End Sub
Sub PANEL_Command_Parse(Comandi As String)
'*** Elaborazione Comandi inviati da REMOTE PANEL
Dim Comando As String
Dim ParComando As String
Do
If Len(Comandi)=0 Then Exit Do
'Pulisci caratteri non attesi
Do
Comando=Mid(Comandi,1,1)
If Asc(Comando)>=65 And Asc(Comando)<=90 Then Exit Do
If Len(Comando)>1 Then
Comando=Mid(Comando,2)
Else
Comando=""
Exit Do
End If
Loop
If Comando<>"" Then
'Comando Presente
ParComando=Mid(Comandi,2,3)
If Len(ParComando)=3 Then
Call PANEL_Command_Exec (Comando,ParComando)
End If
Comandi=Mid(Comandi,5)
Else
Comandi=""
End If
Loop
End Sub
Sub PANEL_Command_Exec(Comando As String,ParComando As String)
'*** Esegui comando inviato da Panelli Remoto
Dim NInput as Integer
Dim SInput as Integer
Select Case Comando
Case "B"
Select Case ParComando
'X+
Case "010"
Case "011"
Call DoOEMButton(307)
'X-
Case "020"
Case "021"
Call DoOEMButton(308)
'Y+
Case "040"
Call DoOEMButton(335)
Case "041"
Call DoOEMButton(309)
'Y-
Case "050"
Case "051"
Call DoOEMButton(310)
Case "031","030"
Loop_Exit=TRUE
End Select
Case "I"
'Input
NInput=CINt(Mid(ParComando,1,2))
SInput=CINt(Mid(ParComando,3,1))
Call SetUserLED (1100+NInput, SInput)
Case Else
End Select
End Sub
Sub COM_Open
'Apertura COM
'Set objCOM = WScript.CreateObject ("MSCOMMLib.MSComm", "MSCommEvent_")
objCOM.CommPort = 1
If Not(objCOM.PortOpen) Then
objCOM.InputLen = 1
objCOM.InputMode = 0
objCOM.RThreshold = 0 ' Non viene generato l'evento
objCOM.Handshaking=2
'objCOM.RTSEnable=True
objCOM.NullDiscard=True
objCOM.InBufferSize=10000
objCOM.OutBufferSize=10000
objCOM.Settings = "57600,n,8,1"
objCOM.PortOpen = True
vbCrLf = Chr(10) & Chr(13)
End If
End Sub
Sub COM_Close
If objCOM.PortOpen Then
objCOM.PortOpen = False
End If
End Sub
Sub COM_Out_Wait
Dim RS232_WaitMaxTime As Integer
'Attendi inviao Completo
RS232_WaitMaxTime = 2 'Secondi
RS232_ResponseOK = False
SetTimer(1)
Do
If objCOM.OutBufferCount=0 Then
Exit Do
End If
If GetTimer(1) >= RS232_WaitMaxTime Then Exit Do
Sleep 10
Loop
End Sub
Sub COM_Clean
Dim RS232_IN_Tmp AS String
Do
Sleep 10
'Dati in arrivo
RS232_IN_Tmp=objCOM.Input
Else
Exit Do
End If
Loop
End Sub
Sub COM_Out_Line(Testo As String)
objCOM.Output =Testo & Chr(10) & Chr(13)
Call COM_Out_Wait
End Sub
I am sorry to say that I don't think you can do that in the Macro pump :( it is code that gets run once an update not all the time... The stuff that you are looking to do would be best done in C++
Brian
Hi.
With the last update 2.3 there is not anymore the problem about the error with CreateObject in the MacroPump.
I've done some test and it looks to work well also at 115200 baud.
As soon as possible we will test this remote panel on a milling machine and we will find out what kind of problem we will get.
Bye
Gianfranco Fazzini
