Mach Discussion => General Mach Discussion => Topic started by: sully3535 on February 10, 2018, 11:27:06 AM
Title: MAch 3 stops working
Post by: sully3535 on February 10, 2018, 11:27:06 AM
When I reboot my computer mach 3 will move my router normal for about 15 seconds. Then it stops moving. motors make noise but little or no movement.
Title: Re: MAch 3 stops working
Post by: joeaverage on February 10, 2018, 08:30:56 PM
going to need a lot more info than that before anyone could make a guess.
What PC do you have?
What OS is installed, especially is it 32 bit or 64 bit?
What is your motion controller....parallel port or UC100 or Smoothstepper or....?
If its a parallel port machine what does DriverTest.exe reveal, and I mean a screen shot not some meaningless 'excellent' or 'pulsing to fast'?
Post by: sully3535 on February 12, 2018, 02:03:52 PM
Windows XP
64 Bit
Pulse frequency drops from 29000 to 1000 and is erratic after that. When the pulse frequency drops the motors stop working.
Post by: joeaverage on February 12, 2018, 03:21:55 PM
the parallel port driver won't work on 64 bit.
What external motion controller are you using?
Post by: sully3535 on February 12, 2018, 04:00:42 PM
Must be 32 then. It has worked for years.
Post by: joeaverage on February 12, 2018, 04:46:08 PM
you could try loading the port driver anew. You'd have to use the control panel to dig out the old driver and
then install anew.
Post by: joeaverage on February 12, 2018, 05:39:06 PM
have you loaded any new programs recently? Maybe one of them is stuffing up the parallel port driver.
Post by: sully3535 on February 13, 2018, 04:00:52 AM
No new programs.
Post by: sully3535 on February 13, 2018, 06:06:10 AM
Is it possible the problem is with my power supply? I believe that just went out on me.
Post by: Tweakie.CNC on February 13, 2018, 06:17:35 AM
Sounds like a reasonable assumption. Perhaps check the power supply output with a multimeter to confirm.
Post by: sully3535 on February 16, 2018, 12:44:52 PM
It was the power supply. Got a new one, installed it, a few tweaks to Mach3 and it works great.
