Mach Discussion => General Mach Discussion => Topic started by: rcaffin on January 19, 2018, 04:15:42 AM
Hi all
Just sometimes I want to machine around a curve which is not a circle, so I calculate the points using trigonometry. That is fine until I get to 360 degrees. In the real world
sin(360) = sin(0) = 0
tan(360) = tan(0) = 0
cos(90) = sin(0) = 0
On my Mach3 V0.062 I get something a little different.
sin(360+0.01) = 0.0001745 (correct)
sin(360) = -2.4492
cos(90 - 0.01) = 0.0001745 (correct)
cos(90) = 6.1230317
Of course, neither sin() nor cos() can ever be >1.000.
Has anyone else met this problem?
Roger
Some more details.
The problem seems to be with the G-code var monitor, NOT with the trig per se.
If I have the g-code var monitor active and type into the MDI line #1=123 I get 123 in the box for #1.
If I type #1=sin[30] I get 0.5 in the box for #1.
If I type #1=sin[360] I get -2.4492.
BUT
if I type g0 x[sin[360]] the X DRO goes to 0! As it should.
Other tests match.
Which is an almighty PAIN, as a lot of my debugging involves (relies on) using the Var Monitor.
Roger
