Mach Discussion => General Mach Discussion => Topic started by: Cartierusm on January 08, 2018, 09:43:51 PM
So I've got a Mori Seiki SL1 lathe that I fully rebuilt with all new stuff and Mach 4 and I'm thinking about buying a Fadal VMC to replace my home built Bridgeport CNC. My Bridgeport CNC has been awesome, but I'm looking for more capacity and tool changer. I don't want to retrofit it but as Fadal's are old I want to be prepared to in case the electronics go.
SO I was wondering what cool features Professional CNC's have.
Here are some examples of physical features and neat programming ideas:
1. Tool Changer
2. Spindle Load - to know how much load is on the tool.
3. Seen some neat g-code manipulation where they have the machine spray coolant while moving the carriage around to clean it off after the part is finished machining.
Any other things a professional lathe or vmc would have?
I've been looking for used VMC to replace my converted Bridgeport - did you find one yet at a usable price?? Seems they have all gone up in value
I have spindle power on my BP - the VFD outputs it so i sent it to the CSMIO and that shows it on screen, very useful.
Not really. All the machines I find are in the 10k-20k range. I'm willing to spend some money as the Bridgeport conversion, if done correctly can fetch 8k, I think. You might want to consider that.
Let me get understand this - the VFD you're using can output how much power is being used? Then you send that out via CSMIO to Mach 4 so you can see the spindle load? Interesting and very creative.
Got a couple of obvious ones I forgot to add:
4. 4th Axis.
5. Rigid Tapping
Also got rigid tapping on my BP :) Works well at lower speeds as its only a standard motor not servo drive so if you go too fast it will over-shoot but not been an issue yet.
It also has two spindles, one goes to 24k. All controlled with the same control cabinet, i fitted as many bells as i could when i built it ;)
Yes the VFD outputs it as a signal IIRC and that goes to an analogue input on the controller.
Junk rebuilder VMCs seem to have dried up now, as you say they are all 5k plus, then you need 5k on controls/rebuild and thats if the ways are not shot.
Sometimes you can get pretty lucky finding some good iron if the machine is just for parts. We found a 1997 Haas VF3 for 4k in Illinois a few years ago.
As far as features
Having a Tool Measure Probe to get THO
We even set up a macro to check our drill, using our probe, to see if it broke before our tap.
Definitely I'll add those to the list
6. Optional High Speed Spindle
7. Probe for Part Location and THO
8. Macros for Broken or Worn Tools
4k for a Hass....dammm
Yep. It was in need of a totally makeover; control and axis needed changing. But it is a good and accurate machine.
If you end up going with Mach4, you can do quite a lot with LUA. You can integrate any idea you have with the Screen, GUI.
You say that!! I have no idea of how the screen, GUI and LUA work. I'd like to, but am clueless.
I ran a pair of Fadals. They are known for the fact that Fadal used lots of standard parts and are mechanically very simple machines so very easy to work on. They have box ways with turcite liners which is easily replaced, they use a PC style keyboard and a very standard CRT monitor not some funky special. So they are usable and resellable. Major complaint today is that they are not fast, especially the umbrella style tool changers with a geneva mechanism. About 10 seconds to change a tool. I've seen machines that do it in under 1 second! The macro language in a Fadal is a version of Microsoft Mbasic! I used to do lots of macro programming before we had CAM. Fadal has a toolpath simulator that ran on DOS that you could test your program on. Crude but it let you know you weren't cutting the end off the table with a face mill!
The one thing that I appreciate about Mach running on Windows is that I can also run a CAM program right on the machine and it takes seconds to post program change. But windows is so unreliable when compared to commercial CNC or a PLC that the difference is stunning and costly. I'd like to see 100% of the machine control function in the machine with a Windows HMI program only. The machine should run standalone or from files selected on an SD card. Oh yeah the 3D Printers already do this!
Setting up a machine with Mach to compare to high dollar controls would be a very difficult task. But as far as a windows based professional controller.... I was pretty sure Hurco uses a windows based control. And Haas uses Linux as their base CPU.
Spindle load - my spindle is driven by a brushed DC motor. I stuck an ammeter in the circuit.
Normally it shows < 0.5 A. I was drilling titanium one day a bit too fast, and the ammeter got up to about 6 A. Oops! Change of Feed rate.
An AC ammeter on the input to the VFD?
Roger
Many VFDs can output an analog signal that tells you the current or other interesting things. All you have to do is read it. If you are using Modbus then I believe it can be read that way too.
One of my projects it to read the spindle current and servo load using my analog inputs on my DSPMC.
Could probably be done on an Arduino and then sent into Mach via Modbus. IIRC Mach 4 allows for more than one slave.
My main point is that you don't have to send the info back to Mach. You can stick it on an analog panel meter as a totally passive display, somewhere out front. I find that works just fine.
Roger
My Bosch VFD has an extension kit that allows you to mount the VFD display on a panel elsewhere.
Roger
Hi Roger,
My main point is that you can and have it display on the Computer screen, no need for a separate display.
You can even tie it to the feed override and if the spindle load gets too high you can slow the feedrate to compensate.
Both ways of doing it have their place.
Mike
That would be neat.
