Mach Discussion => Mach4 General Discussion => Topic started by: Firechief on January 08, 2018, 01:47:57 PM
I heed some help with finding the current tool edge. I working on a XYZ 0. I got it to find XYZ 0 but the setting is to the side (XY) of the tool not the center. Any help with the lua code would be great.
This should help
https://www.youtube.com/watch?v=VA49atQNzmg
I,m working in the Lua code with a coroutine. Got everything working finding all XYZ just need to get the center of the bit not the edge on the XY.
Thanks for your help
You can get the center of the tool by using
local center = mc.mcToolGetData(inst, mc.MTOOL_MILL_RAD, 1);
assuming you are using the tooltable, from here you can add or subtract it to your XY Coords
DazTheGas
Thank for the help...
I got this to work
