Mach Discussion => General Mach Discussion => Topic started by: Tuffluck Designs on January 06, 2018, 08:25:20 PM
Title: Code stops at line 488
Post by: Tuffluck Designs on January 06, 2018, 08:25:20 PM
I'm ramping down to a depth on a slot and the code repeats x and y after line 488. I checked the flash drive I'm using and the code is all there. Also tried a different flash drive and the same result. Also tried reprogrammed only one of the three slots and also the same thing.
Sent from my XT1650 using Tapatalk
Title: Re: Code stops at line 488
Post by: Tweakie.CNC on January 07, 2018, 12:36:32 AM
If you are using Mach3 in Demo mode then it is limited to ~500 lines of code.
The Mach3 license removes this limitation; http://www.machsupport.com/shop/mach3/
Post by: TOTALLYRC on January 07, 2018, 03:48:29 AM
You should also not run from the flash drive but copy the file over to the hard drive.
Mike
