Mach Discussion => General Mach Discussion => Topic started by: ronald4418 on December 31, 2017, 02:38:34 AM
Title: Mach 3 Homing switches wiring with Gecko G540
Post by: ronald4418 on December 31, 2017, 02:38:34 AM
After searching the various responses concerning the wiring of Homing Switches to a Gecko G540. I'm confused about switches that are designed to be run in a Normally Open Configuration when the Gecko PDF states that the G540 is designed to operate Homing Switches in a Normally Closed Configuration.
Is there a way to modify what Mach3 sees such as changing from Active High for Normally Closed to Active Low for Normally Open?
Title: Re: Mach 3 Homing switches wiring with Gecko G540
Post by: TPS on December 31, 2017, 04:23:12 AM
Config -> Ports&Pins -> Input Signals -> Collum Aktive Low
Post by: ronald4418 on December 31, 2017, 12:23:45 PM
Thanks for clarifying what I was assuming to be correct.
Post by: Baldwelder on January 19, 2018, 04:17:59 AM
The problem with active low configuration is, If a wiring fault occurs you wont know until your head crashes into the table or boundaries. Active high is much safer and E-stops if there is a fault.
Post by: TOTALLYRC on January 19, 2018, 04:31:27 AM
Not really a problem for homing switches as long as his e-stop and limits are normally closed.
Mike
Post by: Baldwelder on January 19, 2018, 05:29:44 AM
Ok, for a brand newbie, I have the mechanics together(minus the limits switches) but there`s a difference between a homing switch and a limit switch?
Post by: Overloaded on January 19, 2018, 07:27:28 AM
Greetings !
There's a GREAT BIG section regarding this in the set-up manual ..... well worth a read, its well written and quite clear. Even for a brand newbie .... like I was.  :)
Russ
Post by: Baldwelder on January 19, 2018, 07:55:23 AM
Haha - I knew there would be but I`m so newbie I wasn`t even sure where to look.
Thanks for the pointer. ;D
