Mach Discussion => General Mach Discussion => Topic started by: Planobilly on December 29, 2017, 12:49:14 PM
Title: Are the G Codes at the top right of the main screen all the active codes?
Post by: Planobilly on December 29, 2017, 12:49:14 PM
I assume the codes at the top right of the main screen are the ones that are active. Correct?
Why would g97 and g94 be active for a mill program? I assume g97 and g94 are for turning applications.
Billy
Title: Re: Are the G Codes at the top right of the main screen all the active codes?
Post by: ger21 on December 29, 2017, 06:07:35 PM
G94 would be the standard mode for Mill. Alternatively, you could use G93.
I don't know what G97 is, as it's not listed in either the Mach3 Mill or Lathe manuals.
Post by: Tweakie.CNC on December 30, 2017, 01:11:01 AM
Just in case anyone is curious about the G97…
Constant Surface Speed never really worked correctly in Mach3 and it’s implementation was eventually discontinued. Having the G97 active ensures the spindle will be operating in RPM mode.
Graham Waterworth describes the relevant commands in this thread; http://www.machsupport.com/forum/index.php/topic,5494.msg37162.html#msg37162
